mb2577
Nov 10, 2021Aspirant
Orbi RBK353 keeps rebooting
Hi. I insalled an Orbi RBK353 system at the end on May and after a couple of weeks it started to lose wi-fi with the LEDs going through the process of updating the configuration setting, accordin...
mb2577
Nov 21, 2021Aspirant
Hi.
I don't know what 'bridge' mode is but the Virgin hub is definitely in modem mode. Just rebooting the router to see if it makes any difference. The only thing that I have ever changed on the router are the SSID, wi-fi and admin passwords.
Mick.
michaelkenward
Nov 21, 2021Guru - Experienced User
Bridge mode is another term for modem only mode. (Confusingly, there are also other "bridge modes".) Many manuals refer to it as bridge mode. That is also how to do a web search for modem only mode.
Unfortunately, there is a lot of confusion around these things. People sometimes turn off the wifi on a modem/router and think they are in modem only mode. Nope. They have just turned off the wifi.
Some ISPs – think the dreaded BT – also supply modem/routers that you just cannot put into modem only mode.
