Pandylin
Sep 13, 2021Aspirant
Orbi RBK353 which includes RBR350 and 2 satellites keep intermittently dropping internet connection
The Orbi was perfect for the first 4 months of having it and now in the past 2 months it has just been intermittently dropping out of internet connection. Our devices connect to it fine but the orbi ...
Sep 13, 2021Guru - Experienced User
Ensure your use good quality LAN cables. CAT6 is recommended.
Looing at your picture, it would NOT be recommende to place the RBR inside a cabinate like that. Maybe leading to problems your seeing and also not good for air ventalation. Placement out in a open area on a desk or shelf is recommended in a open space.
Pandylin
the catHi there!
It is currently running the newest firmware version V4.4.0.10_2.10.63 on the router and both satellites. I was previously using the Cat5E cable that came with the orbi but I believe that was kinked with the initial installation and replaced it with a new CAT5E cable and it seems to be more stable.
After NZ Lockdown is over I'll get a cat7 cable just to ensure everything will be consistent and rule out if it is the cable's issue or not.
The Model and manufacturer for the ONT is found here https://www.chorus.co.nz/q/model-type-200, it is the standard one issued to everyone in NZ.
The Orbi was perfectly fine in the network box for its initial 4 months or so, with zero minor ping spikes or constant disconnections. Devices always connect to the orbi fine so I don't believe its a device connection side issue rather it's more of an issue with orbi connecting to the ISP/internet it self
- FURRYe38Sep 14, 2021Guru - Experienced User
Contact the ISP and have them check the line and the ONT. Try different port on the ONT to the RBR.
Power OFF the ONT and RBR for 1 minute then back ON.
Try the RBR out side of that box cabinet.
