Brad21
Mar 25, 2021Aspirant
Orbi RBK50 delay in connecting to internet
Orbi Mesh RBK50 with satellite (purchased 2018) and Surfboard SB6141 DOCSIS 3.0 cable modem (purchased 2013) connected to Comcast. Comcast says signal to modem meets specs. Desktop connected via et...
Mar 25, 2021Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
The cable between the modem and RBR of good quality? CAT6 is recommended.
Has Traffic Meter been enabled on the RBR? Disable it if it is.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
