eblues's avatar
eblues
Guide
Apr 29, 2022
Orbi RBK653 Mesh
I'm looking get in on the cheaper side of WiFi 6 and Tri-band with two satellites. The router is on one end of the house, so I'll need to daisy chain the two extenders to reach the opposite end, abou...
  • plemans's avatar
    Apr 30, 2022
    If you're daisy chaining, I'd highly recommend the triband satellites. The dual bands take a significand speed hit when daisy chained.
    The only time I recommend the dual bands is if you're planning on hardwiring in the satellites. Then it performs fine.
    If you don't mind renewed, there's been some renewed orbi's on amazon
