eblues
Apr 29, 2022Guide
Orbi RBK653 Mesh
I'm looking get in on the cheaper side of WiFi 6 and Tri-band with two satellites. The router is on one end of the house, so I'll need to daisy chain the two extenders to reach the opposite end, abou...
- Apr 30, 2022
If you're daisy chaining, I'd highly recommend the triband satellites. The dual bands take a significand speed hit when daisy chained.
The only time I recommend the dual bands is if you're planning on hardwiring in the satellites. Then it performs fine.
If you don't mind renewed, there's been some renewed orbi's on amazon
Apr 30, 2022Guru - Experienced User
eblues
Apr 30, 2022Guide
Thanks for taking the time to reply to this hit and run. You confirm my suspicions. I'll check out the renewed options, I've gone that route few times.
How Is the tri-band router paired with dual band satellites setup ever beneficial? I'm having trouble understanding how it could be. The satellites can't communicate with the router on the 2nd 5ghz channel, can they?
