eblues
Apr 29, 2022Guide
Orbi RBK653 Mesh
I'm looking get in on the cheaper side of WiFi 6 and Tri-band with two satellites. The router is on one end of the house, so I'll need to daisy chain the two extenders to reach the opposite end, abou...
- Apr 30, 2022
If you're daisy chaining, I'd highly recommend the triband satellites. The dual bands take a significand speed hit when daisy chained.
The only time I recommend the dual bands is if you're planning on hardwiring in the satellites. Then it performs fine.
If you don't mind renewed, there's been some renewed orbi's on amazon
eblues
Apr 30, 2022Guide
Thanks for the info guys. Very helpful.I'm slightly more network savvy today than I was yesterday.
In regards to the AX3000 spec, could it be as simple as (4200 + 1800) / 2?
Apr 30, 2022Guru - Experienced User
It could be. Just doesn't make a whole lot of sense but neither does pairing dual band satellites with a triband router.
