Manny_B
May 30, 2021Tutor
Orbi RBK750 issue with ps5 and Sky q
I have a 1gb internet service from virgin media and have put the Virgin media router into modem mode and the Orbi RBK753 into router mode on the ground floor. I have 2 satellites not too far - one on ...
- May 30, 2021
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satelliteTry turning OFF 1 of the RBS.
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 or 48 channel on 5Ghz.
Armor, Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347 and Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).Can you wire both PS5s to the RBS?
May 30, 2021Guru - Experienced User
Manny_B
Jun 01, 2021Tutor
Apologies for the delay in responding but I have now followed your suggestions including wiring one console directly to a satellite and amending the settings in the orbi.
Seems all stable now!-thank you
