NT53
Nov 03, 2021Follower
Orbi RBK752 - Connecting to internet with Satellite via Ethernet connection
Hello All, Issue: My ISP modem is downstairs, and I want to hook up my PC with ethernet which is upstairs. Yes, I can run a cable, but I am trying to find the quickest and easiest way without hav...
Nov 03, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Yes.
Thank you
