Mocs123
Jan 07, 2021Aspirant
Orbi RBK752 - Devices will not connect to satellite
I have a new Orbi RBK752 system with the router on the main level in my office and the satellite in my son's room upstairs. He has a computer and X-Box hard wired in to the satellite which seem to...
Jan 07, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
Mocs123
Thank you. Turning the power down to 50% fixed the issue and everything is able to connect.
- FURRYe38Jan 07, 2021Guru - Experienced User
Good to hear. Please mark your thread as solved so others know.
Enjoy. :smileywink:- rensulFeb 28, 2021Guide
I'm also having this same problem but it only started happening in January. Why do I need to lower the radio power when it has been working fine all along? I'm concerned that lowering the power will cause other problems and then I have to troubleshoot and ask forum questions blah blah blah. It was working fine what changed?
