andrenb's avatar
andrenb
Orbi RBK752 - region change won´t stick
I gave one of my sets of Orbi RBK752´s bought in Norway (Europe) to family living in Brazil when they where visiting. The region selection is active in the webgui but it doesn´t seem to stick for th...
  • CrimpOn's avatar
    CrimpOn
    Nov 08, 2023
    Fortunately, there appears to be little difference in radio restrictions between Europe and Brazil.
    (Brazil is on the far right side of the table)
    https://en.wikipedia.org/wiki/List_of_WLAN_channels
    I, also, wonder what in the world caused Netgear to include a feature that simply doesn't work on some products.  Just speculating, but perhaps they have marketing contracts that give certain vendors exclusive rights to distribute products in geographic areas.  Maybe it is a way to keep customers from purchasing a product where it is less expensive and then transporting it to a place where the prices are higher?  Nobody knows.
