andrenb
Nov 07, 2023Aspirant
Orbi RBK752 - region change won´t stick
I gave one of my sets of Orbi RBK752´s bought in Norway (Europe) to family living in Brazil when they where visiting. The region selection is active in the webgui but it doesn´t seem to stick for th...
- Nov 08, 2023
Fortunately, there appears to be little difference in radio restrictions between Europe and Brazil.
(Brazil is on the far right side of the table)
https://en.wikipedia.org/wiki/List_of_WLAN_channels
I, also, wonder what in the world caused Netgear to include a feature that simply doesn't work on some products. Just speculating, but perhaps they have marketing contracts that give certain vendors exclusive rights to distribute products in geographic areas. Maybe it is a way to keep customers from purchasing a product where it is less expensive and then transporting it to a place where the prices are higher? Nobody knows.
andrenb
Nov 08, 2023Aspirant
But why make the Region selection-setting available in the webgui if it isn´t actually meant to do anything?
Under you see the settings on the European Orbi RBK752-set I own, which is the same as the set we are trying to get to work properly in Brazil:
CrimpOn
Nov 08, 2023Guru - Experienced User
- andrenbNov 11, 2023Aspirant
Suddenly the RBK752´s I use back in Norway decided to stick to "South America"-setting I put it in to test and is broadcasting the land code BR. No idea why it suddenly started to obey the region selection in the web gui.
- FURRYe38Nov 12, 2023Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
