maxpatlick
Jul 25, 2020Aspirant
Orbi RBK752 AX4200 disconnects from internet
I bought this about a month ago, and for the whole month it was flawless. Return window closed on the 22nd, now suddenly today it's been super unreliable. It started at around 11am, i lost internet...
- Jul 25, 2020
modem is a spectrum docsis 3.0 with VoIP. the satellite is close enough, connectivity between the satellite and router is not an issue. Like I said, the whole local network is fine, the issue is WAN.
since I updated the firmware on the satellite, the connection has been stable. that doesn't sound like it makes any sense to me either, but I'll take it. If it happens again, a factory reset will be the next step I try though, thanks.
Jul 25, 2020Guru - Experienced User
Factory reset the RBR and RBS and setup from scratch. Press the back reset button for 15 seconds then release.
maxpatlick
- FURRYe38Jul 25, 2020Guru - Experienced User
Enjoy. :smileywink:
