yukaveli
Jun 02, 2022Aspirant
Orbi RBK752 causing 4G modem (c4r400) to lose internet connection every minute
I just recently got a Verizon Sim card with a GTEN c4r400 lte 4g modem for home internet. I'm in a rural area and don't have many options. I have a Verizon tower within line of site, and I have a Ver...
Jun 02, 2022Guru - Experienced User
Why not leave the modem in router mode and put the orbi in access point mode?
Just make sure to use seperate ssid's and have them on different wifi channels to prevent interference
- CrimpOnJun 02, 2022Guru - Experienced User
I agree with plemans that the most obvious solution is to set the GTEN 2.4G WiFi to a channel far away from the Orbi 2.4G WiFi.
The GTEN has no 5G WiFi, so the only possible interference would be on the 2.4G channel.
My first thought was, "Before blaming the Orbi, let's see what the GTEN documentation says about connecting routers to the device."
However, I was unable to find a user manual or 'support' option on the GTEN web page:
http://www.gten-sz.com/product/showproduct.php?id=169
- yukaveliJun 06, 2022AspirantThank you.
I appreciate your help. For some reason my Orbi switched back to router mode. I didn't realize it changed. I've switched it back to access point mode, and it's working great.- FURRYe38Jun 06, 2022Guru - Experienced User
