srinivasgnv
Sep 27, 2021Guide
Orbi RBK752 LED Magenta once every 3 days
I was using Netgear WNDR3700v3 that was perfecting working but decided to upgrade to wifi6. So, I recently purchased RBK752 (RBR750 and one RBS) two week ago. Just replaced my older router with Orbi....
- Oct 03, 2021
Finally I could conclude that disbaling DHCP in my ISP (BSNL) FTTH modem, resolved this problem. Well, as of now I don't need the DHCP service as the only device I connected (wired) is my orbi router. So I am happy with this workaround for now. I need to do a factory reset and check if this issue is fixed, but that is for the future and I will remind myself.
Thank you very much for staying with me FURRYe38.
Sep 27, 2021Guru - Experienced User
srinivasgnv
Sep 27, 2021Guide
No, I haven't done a factory reset. I unboxed, updated the firmware and started using it. I will wait to see if the issue reoccurs, I will try the factory rest and setup. (Just want to avoid connecting all of my devices and disrupting the network)
- FURRYe38Sep 27, 2021Guru - Experienced User
đ
- srinivasgnvSep 28, 2021Guide
Quick update... The workaround (disabling DHCP Service in the ISP modem and moving to static IP) seems to be working. Three days passed without any instance of Orbi RBR752 turning Meganta while healthy internet on the modem.
I want to test the workaround for three more days before concluding that the workaround is working.
I need to understand the root cause (without the workaround) and/or factory reset when the time is right for my network.
- FURRYe38Sep 28, 2021Guru - Experienced User
đ
