srinivasgnv
Sep 27, 2021Guide
Orbi RBK752 LED Magenta once every 3 days
I was using Netgear WNDR3700v3 that was perfecting working but decided to upgrade to wifi6. So, I recently purchased RBK752 (RBR750 and one RBS) two week ago. Just replaced my older router with Orbi....
- Oct 03, 2021
Finally I could conclude that disbaling DHCP in my ISP (BSNL) FTTH modem, resolved this problem. Well, as of now I don't need the DHCP service as the only device I connected (wired) is my orbi router. So I am happy with this workaround for now. I need to do a factory reset and check if this issue is fixed, but that is for the future and I will remind myself.
Thank you very much for staying with me FURRYe38.
Sep 28, 2021Guru - Experienced User
đ
srinivasgnv
Oct 03, 2021Guide
- FURRYe38Oct 04, 2021Guru - Experienced User
Enjoy.
