RJG202
Nov 12, 2023Guide
Orbi RBK752 max users question and location question
Quick questions on users and distance. The 752 meets my guest and iot requirements. We are not gamers., average number of users is 20 right now with 2 work from home/zoom calls several smart tvs and ...
- Nov 12, 2023
Mimo was a bit of a gimmick in those generations.
Why You Don't Need MU-MIMO - SmallNetBuilder
Its getting better with the AX/BE generations but the AC versions didn't really have much benefit.
I've used flagship 4x4 routers and orbi 2x2 setups and didn't really notice much difference. You might see a bit of speed benefit if you're pretty close to the flagship router but otherwise, not much at all.
RJG202
Nov 12, 2023Guide
Thanks. We are not power users or gamers. Other than basic Netflix and working from home via vid connection running zoom through vdi. Was concerned about 2x2 mimo but I realize nighthawk was gaming router. My cable line and main TiVo are at one end of home.
Thanks
Thanks
Nov 12, 2023Guru - Experienced User
- RJG202Nov 12, 2023GuideThanks, it is hard sometimes to change. I looked at 6e too but I don’t have a clear line of sight to router and I seen several papers or messages saying it drops back to 5g anyway. I will wait for 7 to drop in price and more devices to make use of it. The 752 I got a great price on and honestly with the help of this forum it checks all the boxes for my needs. Hey anything is better than the 1200 baud dial up then I was living life with 14.4. Thanks again
