duffymo
Oct 04, 2020Aspirant
Orbi RBK752 No Internet Connection
Xfinity is my ISP. The cable modem connecting to the internet is locating in a room above my garage, connecting to my desktop. I extend wi-fi through the downstairs portion of my house using three ...
Oct 04, 2020Guru - Experienced User
Please post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Power OFF the ISP Modem and RBR for 1 minute. Then back ON with the modem first, then the RBR. Be sure to use port #1 on the modem for the RBR ethernet cable.
duffymo
Xfinity voice and data modem:
CISCO DPC3941TSerial #: 48F7C0D3CE0D
Firmware is up to date.
- FURRYe38Oct 05, 2020Guru - Experienced User
Your ISP modem already has a router built in. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-ModeTry option 3 first to see if this works.
Be sure your using a good quality LAN cable between the modem and Orbi router. CAT 6 is recommended.
Be sure you use LAN#1 port on the back of the modem...
