lostpty
Feb 20, 2022Aspirant
Orbi RBK752 Public IP Connection Issues with Grandstream UCM6202
I have an Orbi 6 (RBK752) WiFi Mesh System in my home network. Recently I purchased a Grandstream UCM6202 IP PBX. I have been able to configure the device properly to work within my network without...
Feb 20, 2022Guru - Experienced User
- lostptyFeb 20, 2022Aspirant
Orbi Router Firmware Version: V4.6.5.14_2.0.54
Internet Provider Modem: Arris TG2482A
- FURRYe38Feb 20, 2022Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry option #1 first, if not, #2...
The Internet Service Provider modem is acting only as a modem. My ISP locks the modem so their clients cannot change the configuration.
As I mentioned in my original message, this is a similar setup I am currently using at the office. I am using the same modem but at the office I have a Microtik router. I have tried to configure the Port Forwarding to the UCM IP PBX network IP, but it does not seem to connect my external devices.
I´ve contacted Grandstream and they recommend I contact Netgear.
Please confirm Orbi has experience connecting the Grandstream UCM IP PBX to the public IP so my softphone and external extersion work. My experience with Orbi up to this point has been seemless. I hope you are able to help me with this last step with connecting my IP PBX.
