lostpty
Feb 20, 2022Aspirant
Orbi RBK752 Public IP Connection Issues with Grandstream UCM6202
I have an Orbi 6 (RBK752) WiFi Mesh System in my home network. Recently I purchased a Grandstream UCM6202 IP PBX. I have been able to configure the device properly to work within my network without...
lostpty
The Internet Service Provider modem is acting only as a modem. My ISP locks the modem so their clients cannot change the configuration.
As I mentioned in my original message, this is a similar setup I am currently using at the office. I am using the same modem but at the office I have a Microtik router. I have tried to configure the Port Forwarding to the UCM IP PBX network IP, but it does not seem to connect my external devices.
I´ve contacted Grandstream and they recommend I contact Netgear.
Please confirm Orbi has experience connecting the Grandstream UCM IP PBX to the public IP so my softphone and external extersion work. My experience with Orbi up to this point has been seemless. I hope you are able to help me with this last step with connecting my IP PBX.
Feb 20, 2022Guru - Experienced User
Confirm that the modem is in modem only mode by let us know if you see a ##.##.###.### address on the RBRs Advanced Tab/Internet section page or a private IP address of 10 or maybe a 192 or 172 address here.
Did you disable uPnP before setting up any Port Forwarding configurations and set a IP address reservation for this one devices on the RBR?
Disable any PF configurations and try putting the devices IP address into the RBRs DMZ and test.
