DaSheng
Oct 06, 2021Aspirant
Orbi RBK752 Satellite Seems power up every morning
I have the satellite set up in my storage in backyard, about 80 ft away from the router. Every morning when I walk into the storage with my cellphone (WiFi only), I notice the satellite LED is in soli...
DaSheng
Oct 08, 2021Aspirant
Thanks for your reply. I turned off the light and close the door to took a close look at the LED with my kid together. She said it was not white but yellow. And I also noticed that when the door was opened it was fine. I guessed it was the humidity in the OSB board due to recent rainy days. So it was the connectivity between the satellite and the router.
Oct 09, 2021Guru - Experienced User
AH ok...might try some difference placement or a bit closer in distance to the RBR.
Hopefully thats all it was.
Enjoy.
