Wafflez
Aug 13, 2020Aspirant
Orbi RBK752 Speeds
Hi all, I recently picked up an Orbi RBK 752 AX4200 kit which has the RBR750 and RBS750. My ISP is AT&T Fiber with a 1 Gbps plan. After setting up the Orbi kit, maximum wifi speeds I can get is aroun...
Wafflez
Yeah I wasn't expecting much of an improvement on my wifi 5 devices. But I do have two PCs equipped with Wifi 6 cards and another PC which is hardwired into the satellite node. Speeds are still disappointing right now...
Mikey94025
Aug 13, 2020Hero
> Wired speeds at the RBR is around 500 Mbps down.
We can focus on this issue first (before worrying about why your wireless clients are also seeing slower speeds). Is your Pace 5268AC in bridge mode, i.e., the WAN IP address shown on orbilogin.com is the same as seen at https://canyouseeme.org/? If not then you have Double NAT and putting your modem in bridge mode may increase wired speeds.
