OrbisUser95
Oct 10, 2020Aspirant
Orbi RBK752 vs RBK852
Since my internet provider can only produce speeds up to 940mps, am i better off with the RBK752? Is the extra price paid for by the RBK852 lost because my internet speed will never go over 940mps and therefore I may not benefit from the faster speeds of the RBK852?
OrbisUser95 wrote:Since my internet provider can only produce speeds up to 940mps, am i better off with the RBK752? Is the extra price paid for by the RBK852 lost because my internet speed will never go over 940mps and therefore I may not benefit from the faster speeds of the RBK852?
When you look at the Product Data Sheets, there are other differences between the RBK752 and RBK852. (Number of radios, antennas, ethernet ports, etc.) Whether this would be noticable in your situation is up to you.
Be sure to post about this over in the Orbi AX Forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Both Models support 1Gb ISP speeds. I believe the 8 series has the 2.5Gb WAN port for modems that support the 2.5Gb connection rate, like NGs CM2000 series...
Good Luck.
