mmccurdy
Sep 19, 2021Follower
Orbi RBK752
I cannot get into my router (Orbi151)- it doesn't like my password (or username, hard to say which) and when I answer my security questions (correctly), I get this message:"The information you enter...
Sep 19, 2021Guru - Experienced User
You can factory reset it.
That clears everything back to the defaults.
Push and hold reset for 7-15 seconds while powered on.
That'll get you back to the default
default login: admin
default password: password
