mmccurdy
Sep 19, 2021Follower
Orbi RBK752
I cannot get into my router (Orbi151)- it doesn't like my password (or username, hard to say which) and when I answer my security questions (correctly), I get this message:"The information you enter...
Sep 30, 2021Guru - Experienced User
Wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in for 15 seconds then let go. Power OFF the ISP modem for 30 seconds than back on. Wait for the WHITE led to slowly pulsate on top of the RBR, then log in to orbilogin.com using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on.
mmccurdy wrote:
I cannot get into my router (Orbi151)- it doesn't like my password (or username, hard to say which) and when I answer my security questions (correctly), I get this message:"The information you entered does not match what is saved on the router. Please try again."
I am at a complete loss and have no idea where to go from here. Does anyone have any ideas (short of buying a whole new system)?
