jimsasselli
Oct 27, 2021Aspirant
ORBI RBK753 - General Quetions
A few basic quetions: 1) The blue light on one of my satellite units occasionally turns blue. I know that no colored lights means normal operation, as such I suspect the light is to simply indicate...
Oct 28, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you
1) The blue light on one of my satellite units occasionally turns blue. I know that no colored lights means normal operation, as such I suspect the light is to simply indicate a temporary loss of connection?
2) My network set-up shows the router connected to Satellite 2 and then Satellite 1 (in that order)...should the order be reversed to 1 and then 2, or is this normal/okay?
3) My network set-up also shows a solid line from the Modem to the Router and a dotted line from the Router to each of the satellite units. I suspect the solid line is to indicate a hard wire connectin via CAT-5 and the dotted line is to indicate a wireless connection...correct?
Thanks,
Jim
