jimsasselli
Oct 27, 2021Aspirant
ORBI RBK753 - General Quetions
A few basic quetions: 1) The blue light on one of my satellite units occasionally turns blue. I know that no colored lights means normal operation, as such I suspect the light is to simply indicate...
jimsasselli
Nov 05, 2021Aspirant
jimsasselli
- CrimpOnNov 05, 2021Guru - Experienced User
One of the most frustrating features of the Netgear community forums is that images placed "in-line" using the Photos icon in the task bar above do not appear to others until approved by a forum moderator, which can take hours (or days).
Images that are "attached" using the Browse button in the lower left are available immediately.
So, you went to a lot of effort to post two images, but no one can see them.
- FURRYe38Nov 05, 2021Guru - Experienced User
They are displayed now...
