dazcoutts
Mar 07, 2022Follower
ORBI RBK753 and BT HOME HUB 2 as two routers
I am looking for some advice. I have FTTP with BT which comes with VOIP through the Home Hub2. I purchased the Orbi RBK753 system and have set it up in my house with the router function enabled rathe...
Mar 07, 2022Guru - Experienced User
thats the problem with having them on seperate subnets when you're not using a proper vlan setup.
If the IoT device is smart enough it can route through its own web server. But some (many) aren't.
You can always try putting the netgears IP address into the bt home's DMZ. doubt it'll work but it might.
Your other option is to use the netgears guest ssid. Put the IoT devices on the guest network. many people try th at.
