Ff25m2
Apr 24, 2024Follower
Orbi RBK753 connection through switch
I am looking to set up my orbi and connect satellite through a switch. I'm confused about IEEE. I'm thinking of purchasing GS316P for use. I need a switch as I will be adding security cameras using PO...
Apr 24, 2024Guru - Experienced User
I believe that model switch should work with Orbi, though I don't have that model. Ones I do have that I know that do work:
NG GS-105/108v4 and GS308v3, D-Link DGS-105/108 and HP ProCurve 1400/1800 series switches work for Orbi systems.
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System 📡 ‌‌🛰️
