ssteel05
Jan 20, 2022Aspirant
Orbi (RBK753) Connection to MOCA Network for Xfinity After Changing XB6 Gateway to Bridge Mode
I am stumped how to connect my MOCA network for my TV signals now that I have lost the MOCA onboard adapter on the Xfinity XB6-T Gateway when I changed it to bridge mode. Bridge mode automatically...
- Jan 21, 2022
I solved it.....by adding a ScreenBeam ECB6250 MOCA adapter from my router (ethernet) to the MOCA smart splitter (Amphenol IPGH3M4-VF via coax) I was able to replace the MOCA function that the Xfinity XB6-T gateway did and "re-inject" that signal back into the MOCA network in my house.
ssteel05
Jan 21, 2022Aspirant
Correct....Coax in each room to Xi-DP connector, out the connector through HDMI to the TV
Mikey94025
Jan 21, 2022Hero
ssteel05 wrote:Correct....Coax in each room to Xi-DP connector, out the connector through HDMI to the TV
Thanks for explaining. I believe I also have one of these Xfinity XiD boxes in one of my rooms, connected via coax and feeds HDMI to my TV for cable signals. It still works without MOCA and my Xfinity modem is in bridge mode to my Orbi, though I don't rely upon it for internet service for my TV. How is your setup different?
- ssteel05Jan 21, 2022Aspirant
Sounds the same...how it your coax connected to Xfinity? Through a regular coax splitter straight to the room or through a smart low loss of signal splitter?
- Mikey94025Jan 22, 2022Hero
ssteel05 wrote:Sounds the same...how it your coax connected to Xfinity? Through a regular coax splitter straight to the room or through a smart low loss of signal splitter?
Glad you fixed it. To answer your question, my coax connects to a regular splitter out of the room's wall jack, one split goes to the TV box and the other goes to the Xfinity XB7 gateway.
