ssteel05
Jan 20, 2022Aspirant
Orbi (RBK753) Connection to MOCA Network for Xfinity After Changing XB6 Gateway to Bridge Mode
I am stumped how to connect my MOCA network for my TV signals now that I have lost the MOCA onboard adapter on the Xfinity XB6-T Gateway when I changed it to bridge mode. Bridge mode automatically...
- Jan 21, 2022
I solved it.....by adding a ScreenBeam ECB6250 MOCA adapter from my router (ethernet) to the MOCA smart splitter (Amphenol IPGH3M4-VF via coax) I was able to replace the MOCA function that the Xfinity XB6-T gateway did and "re-inject" that signal back into the MOCA network in my house.
ssteel05
Jan 21, 2022Aspirant
My TV's are connected to the Xi-DP adapters...essentially MOCA adapters that connect to the coax in each room and then HDMI cable from the adapter to the TV. The problem is that since the XB6-T is now in bridge mode and only serving as a modem, it disables MOCA support automatically. I am wondering if I can't just "inject" a MOCA signal back into that coax network by running a MOCA adapter out of the Orbi router and back into one of the unused hybrid ports on the splitter that talks to all the other MOCA ports.
ssteel05
