ssteel05
Jan 20, 2022Aspirant
Orbi (RBK753) Connection to MOCA Network for Xfinity After Changing XB6 Gateway to Bridge Mode
I am stumped how to connect my MOCA network for my TV signals now that I have lost the MOCA onboard adapter on the Xfinity XB6-T Gateway when I changed it to bridge mode. Bridge mode automatically...
- Jan 21, 2022
I solved it.....by adding a ScreenBeam ECB6250 MOCA adapter from my router (ethernet) to the MOCA smart splitter (Amphenol IPGH3M4-VF via coax) I was able to replace the MOCA function that the Xfinity XB6-T gateway did and "re-inject" that signal back into the MOCA network in my house.
ssteel05
Jan 21, 2022Aspirant
Sounds the same...how it your coax connected to Xfinity? Through a regular coax splitter straight to the room or through a smart low loss of signal splitter?
Mikey94025
Jan 22, 2022Hero
ssteel05 wrote:Sounds the same...how it your coax connected to Xfinity? Through a regular coax splitter straight to the room or through a smart low loss of signal splitter?
Glad you fixed it. To answer your question, my coax connects to a regular splitter out of the room's wall jack, one split goes to the TV box and the other goes to the Xfinity XB7 gateway.
