psheld
Mar 19, 2022Tutor
Orbi RBK753 has chucked my Airplay speakers off the network after firmware update
Orbi AX4200 WiFi 6 High-Performance Router (RBR750). (It doesn't fill me with confidence that this community forum doesn't have my Orbi model available in the selection field above. But heh ho.) ...
- Mar 23, 2022
The speakers connected to the AVM once it was changed to the same SSID and password as the Orbi, and then would not connect to the Orbi. Nice try 🙂
So I printed off every single setting and did a full factory reset of the Orbi network. I then reconfigured it just as I had done before, and found myself saying "A-HA!"
Now I don't know exactly when I changed Orbi to WPA3? Was it a day before or after the firmware update? Not more than that surely. Seemed harmless, or the right thing to do in fact, but could this be the culprit rather than the firmware update?
So I got everything back exactly as before but with WPA2, crossed my fingers, and before I went to check the speakers I heard their little chime indicated wi-fi connection was established! 🎉
I went to check KEF.com and found they do not recommend open networks or WEP (no surprise there!) And they add: "The WPA2 security protocol is recommended." Note, KEF does not say: "The speakers are not compatible with more recent security protocols such as the three years old WPA3."
But if the effect is indeed related to the cause here, it would seem that KEF should indeed include that sentence in its documentation, or even better, get their kit compatible with WPA3. I will point them to this thread.
Thanks Mikey94025 and thank you FURRYe38, and thank you [at]netgear on Twitter.
psheld
Mar 22, 2022Tutor
Reading other fora about this problem, I'm discerning that I wouldn't have this problem with the Linksys Velop Multiroom Intelligent Mesh Wi-Fi System, Tri-Band, 3-Pack.
I understand this is the Linksys equivalent to my current Orbi network, but importantly comes with a "Works with Apple Homekit" assertion, which many associate with it being fully accommodating of Apple AirPlay.
It appears Netgear has never made this compatibility claim for Orbi, although equally (with my potentially imminent warranty return of the Orbi system in mind) neither does Netgear point out incompatibility with AirPlay.
With family members visiting this coming weekend for the first time since the pandemic began, it's going to be very frustrating to have our beautiful KEF speakers sitting their completely silent. Grrrr.
Any and all ideas still very welcome. Thanks!
