puffo25
Oct 19, 2021Aspirant
orbi RBK753 nightmare: extender keep getting disconnected from access point
Hello. I have a 200MB fiber in my home. I have a 200 square meters apartment. Few wifi access points near by and I have already checked which channel they are using. I have purcheased an Orbi Mesh W...
Oct 19, 2021Guru - Experienced User
Are you referring to the RBR as the 1 AP and the RBS as the extenders?
200 sq meters maybe too small to have the RBR and 1 RBS all running at the same time.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What happens if you turn OFF both RBS and just run the RBR alone?
puffo25
The internet provider is Telecom Italy (TIM). The hub producer is ZTE model X388. I have the latest firmware for the hub.
The router is connected via ethernet with the Orbi access point (only 1/4 feet away). Than the extenders are connected to the Orbi. They are about 40 feet away. Please note: signal is very good (!). Also according to Orbi, the coverage of my apartment is perfect since in terms of square meters this solution is optimized to 325 square meters (mine is 200!).
The firmware for my Orbi is V4.6.5.14_2.0.54.
Again I have not more than 6 visibile networks in my area and my own is the strongest and the others are quite far away and they also use a different channel.
- FURRYe38Oct 19, 2021Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode
https://kb.netgear.com/19863/Ping-Test-to-determine-Optimal-MTU-Size-on-RouterAlso the distance between the modem and RBR should be 3 to 6 feet from each other.
- puffo25Oct 19, 2021Aspirant
Thanks for your help but there is a BUT: I have a security alarm system in the house with video cams and sensors and everything has been connected to the TIM hub via wifi. So if I disable the wifi the house is not protected any more. Which is something I want to avoid.
Question: previously the TIM hub had both the Band Steering and the Easy Mesh enabled since the hub is also a certified 6+ device. Now I have disabled the Band Steering on the TIM hub. Maybe this will help? Shall I keep active the Easy Mesh on the TIM hub?
Also, to narrow down the problem of being disconnected all the time, I have assigned through the orbi web browser interface a reserved static IP address to my 2 extenders (thanks to Orbi technical support).
You may have too much wifi singnals going on that is causing Noise and Interferences with the Orbi RBS. This is not recommended.
What channels is the TIM modem using on 2.4 and 5Ghz?
