akhilstyle
Jul 29, 2022Tutor
ORBI RBK753 No Connected Orbi Ethernet Backhaul
Hi, I have my RBR connected to some satellites. All of the the Satellites are connected directly to the RBR via ethernet without any switches in between. I have noticed that one of them occas...
Jul 29, 2022Guru - Experienced User
If its still working fine, then I wouldn't worry to much.
If it bothers you, you could always try a factory reset and reinstall.
What firmware version are you on?
