akhilstyle
Jul 29, 2022Tutor
ORBI RBK753 No Connected Orbi Ethernet Backhaul
Hi, I have my RBR connected to some satellites. All of the the Satellites are connected directly to the RBR via ethernet without any switches in between. I have noticed that one of them occas...
Jul 29, 2022Guru - Experienced User
What CAT# lan cable are you using between the RBR and RBS? CAT6 is recommended.
What FW is loaded on the system?
Try swapping RBS location with another RBS to see if the problem follows or not.
akhilstyle wrote:
Hi,
I have noticed that one of them occasionally shows nothing under "connected Orbi". The wifi on this satellite works fine and I am not sure if it is an issue or not. If I reboot the satellite or disconnect and reconnect the ethernet cable, it will show up as Connected to Orbi Router.
- akhilstyleJul 29, 2022Tutor
Thanks for the replies.
FW V4.6.5.14 on all of them
It's Cat 5 - its run in the walls so I cannot change this.
- FURRYe38Oct 31, 2022Guru - Experienced User
Have you updated FW?
Remember CAT5 isn't recommended and is not officially supporting of 1000Mbps. CAT6 is recommended. CAT5 could be causing this odd issue. Something that FW may not help fully resolve.
- akhilstyleNov 02, 2022Tutor
Hi
Thanks for your reply.Yes firmware updated to V4.6.9.11
I have used cat 6 cables
