akhilstyle
Jul 29, 2022Tutor
ORBI RBK753 No Connected Orbi Ethernet Backhaul
Hi, I have my RBR connected to some satellites. All of the the Satellites are connected directly to the RBR via ethernet without any switches in between. I have noticed that one of them occas...
Jul 29, 2022Guru - Experienced User
If its still working fine, then I wouldn't worry to much.
If it bothers you, you could always try a factory reset and reinstall.
What firmware version are you on?
akhilstyle
Jul 29, 2022Tutor
Thanks for the replies.
FW V4.6.5.14 on all of them
Thank you
- FURRYe38Jul 29, 2022Guru - Experienced User
Well if the system is working otherwise, you can leave it for now.
Your behind on FW updates as well. Can keep what's loaded for now. IF and when you do decide to update FW, update the RBS first then the RBR lastly.
CAT5 doesn't officially support 1000Mbps connection rates so you maybe seeing some effect of this.
