akhilstyle
Jul 29, 2022Tutor
ORBI RBK753 No Connected Orbi Ethernet Backhaul
Hi, I have my RBR connected to some satellites. All of the the Satellites are connected directly to the RBR via ethernet without any switches in between. I have noticed that one of them occas...
Sep 07, 2022Guru - Experienced User
Maybe a cabling issue. CAT5 is not recommended and not officially rated for 1000Mpbs connections. Possible some signal on these cables could be degrading enough to cause problems.
You might disconnect all RBS from ethernet backhaul and connect them wirelessly and see if same thing happens.
akhilstyle
Sep 08, 2022Tutor
Thanks for the reply. I have not done a factory reset since FW update.
I will try putting disconnecting them from ethernet
- FURRYe38Sep 08, 2022Guru - Experienced User
