akhilstyle
Jul 29, 2022Tutor
ORBI RBK753 No Connected Orbi Ethernet Backhaul
Hi, I have my RBR connected to some satellites. All of the the Satellites are connected directly to the RBR via ethernet without any switches in between. I have noticed that one of them occas...
ekhalil
Sep 07, 2022Master
akhilstyle wrote:..........
The symptoms I am experiencing are wifi devices, that are already connected to my network (even ones with reserved IP addresses), not getting allocated an IP address (or allocated a 169.254.xxx IP address). This is usually noticeable when I move to a different part of the house (roaming?) and the netgear log shows that the device is asking for an IP address. Or perhaps when the lease time for the IP address ends? This is noticeable on my iOS devices (like iphone/ipad). It is intermittent and lasts for about 2-5 minutes - the circle on the iOS device spins continuously and eventually it will connect.
What other devices do you have in your network wired to Orbi? Do you have smart/mesh speakers, wif repeaters, ....etc?
akhilstyle
Sep 08, 2022Tutor
Hi, No wireless speakers or wifi repeaters. But I do have
2 wired printers
CCTV system
Hue bridge
Hive hub
Sky booster
Thanks
Akhil
- ekhalilSep 08, 2022Master
akhilstyle wrote:Hi, No wireless speakers or wifi repeaters. But I do have
2 wired printers
CCTV system
Hue bridge
Hive hub
Sky booster
Thanks
Akhil
What do you use the Sky booster for? How is that configured and how is it connected to Orbi? Have you tried to disconnect it and see if there will be any effect?
- akhilstyleOct 31, 2022Tutor
Hi,
Thanks for the reply.
The sky booster is for my sky q TV box. It is connected to a switch and connects my sky q TV boxes to each other via a hidden network separate to the Orbi. I disconnected this and had the same problem with the phones not getting an IP address occasionally for a few minutes. After about 5 minutes I finally get an IP address.
I have also connected the satellites to the router with Cat 6 to test this out - but getting the same issue (however I am not noticing this "connected orbi" issue with the cat 6)
- ekhalilOct 31, 2022Master
If there are devices causing IP loops, then disconnecting those devices does not immediately solve the problem, it will take time for the system to stabilize. Does the problem happen again if you keep the sky booster disconnected?
