theMPU
Mar 04, 2022Aspirant
Orbi RBK753 randomly drops internet connection from Comcast XB7 modem
Hello, This is super friggn frustrating as I work from home and also stream. I have the latest XFi Modem/router, set in bridge mode. A Single Gb connection to the Orbi mesh router base unit. Eve...
Mar 04, 2022Guru - Experienced User
what firmware are you on?
Have you noticed a difference if you shut off a satellite/satelliites (checking backhaul)?
When it drops, does it stop broadcasting wifi, does it not connect to the wifi, or does it connect and say "connected, no wifi"
theMPU
firmware is 4.6.5.14_2.0.54 (current)
have not tried to disconnect one of the satellites. local WIFi does not go down. The wifi map when interent is down still shows the hubs connected to the router green and solid connections. I guess I can try that, however in this case, no devices are actviely operating on either satellite.
One additional quick bit of background. I hear the 753 has a limit of 40 connections.. is this active connections or devices which are connected episodically? I hear the 853 is 33 percent more devices and am wondering is there a potential limitation here on how many devices (even lightweight IOT (2.4Ghz) things like smart lights can overwhelm the system.
- plemansMar 04, 2022Guru - Experienced User
A couple things you can try.
1. This version of the firmware: https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-RBR750-RBS750-Firmware-Version-v4-6-7-5-Released/td-p/2182131
2. try putting the XB7 in router mode (disable its wifi) and connect the orbi in access point mode.
