JimTurkey
Sep 24, 2021Guide
Orbi RBK753 setup with U-Verse BGW210 ... I can't mess this up!
My Orbi RBK753 will arrive tomorrow. I have to set it up with my U-Verse BGW210. I've read that this can be tricky with U-Verse and I don't want to mess this up. Please help me. What steps need t...
Sep 24, 2021Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
JimTurkey
Sep 25, 2021Guide
what is the advantage to setting it up as an access point?
- JimTurkeySep 25, 2021Guide
I found this tutorial here. It is using the Orbi as an access point.
Do these directions seem to be correct in your opinion?
- FURRYe38Sep 25, 2021Guru - Experienced User
Yes, seems correct.
Less hassle to setup Orbi since you already have a router wifi system. Orbi will have better wifi coverage and performance than the ATT modem.
Or I found this video that goes through IP Passthrough, turning off the BGW210 wifi, and other steps. Ah! This is so confusing. Why can't there just be 1 way?
