Jermsalerms
Apr 03, 2021Aspirant
Orbi RBK753 Speedtest at 900+ Mbps but devices connected to 5Ghz don’t exceed 600 Mbps
I have FIOS Gigabit. I have the Orbi RBK753 router connected directly to the ONT. Using the Speedtest in the Orbi app on my iPhone I always see the Orbi router itself getting 950+ Mbps upload and 880+...
- Apr 03, 2021
Jermsalerms wrote:
1. I thought if the router was getting 900Mbps and I was connected to the 5GHz I would see similar speeds. Isn’t that to be expected?Unfortunately no. Wireless speeds will be substantially less, especially if your devices are not connecting via WiFi 6 (AX) since 5ghz AC speeds will be even less than AX.
- Only some phones currently support AX (Wi-Fi 6) and will benefit from the Orbi AX's higher speed capabilities - Maximum real world AC speeds will be in the 500s-600s whereas maximum AX speeds can go higher.
Mikey94025
Apr 03, 2021Hero
Jermsalerms
Apr 04, 2021Aspirant
Does that mean that the AX6000 is going to be capped at the same 500-600 Mbps over 5GHz that I am seeing on the AX4200 using the devices I have or would it be worth upgrading?
