Danatt
Jul 07, 2021Follower
Orbi RBK753 wired backhaul slow after power outage
After a power outage I had to re enter the internet setting in my RBR750 because (I don’t know how) the outage changed some values. After this the wired satellite (and the wireless one downstream) we...
Jul 07, 2021Guru - Experienced User
Try powering OFF all units. Including the ISP modem/ONT for 1 minute.
Power ON the ISP modem/ONT first, then RBR. Check speeds here first.
Then power ON the RBS, one at a time. Then test.
