Pdob85018
Nov 10, 2020Aspirant
Orbi RBK753 wired backhaul
I am buying an Orbi AX4200 mesh system with one router and two satellites. They will be configured in a daisy chain (Router - Sat 1 - Sat 2). Is it possible to set up just the furthest satellite (S...
Pdob85018
Nov 11, 2020Aspirant
Thanks! I haven't found much info on the setup proceedure for this...will Orbi automatically configure the wired backhaul when I connect Sat 2 to Router via wired connection?
- FURRYe38Nov 11, 2020Guru - Experienced User
I recommend syncing the RBS wirelessly first the the RBR, then after they are fully connected, connect the ethernet cable to to the RBS from the RBR.
- Pdob85018Nov 11, 2020Aspirant
Thanks again for the advice! My only remaining concern on this is that my wiring for the Router - Sat 2 backhaul is older Cat-5. I'm still thinking this will be better than wireless daisy chain backhaul, but not sure.
Ya, Need to upgrade to CAT6 would be best. CAT5 only supports 100Mpbs vs 1000Mpbs with CAT6.
Pdob85018 wrote:Thanks again for the advice! My only remaining concern on this is that my wiring for the Router - Sat 2 backhaul is older Cat-5. I'm still thinking this will be better than wireless daisy chain backhaul, but not sure.
