Pdob85018
Nov 10, 2020Aspirant
Orbi RBK753 wired backhaul
I am buying an Orbi AX4200 mesh system with one router and two satellites. They will be configured in a daisy chain (Router - Sat 1 - Sat 2). Is it possible to set up just the furthest satellite (S...
Pdob85018
Nov 11, 2020Aspirant
Thanks! I haven't found much info on the setup proceedure for this...will Orbi automatically configure the wired backhaul when I connect Sat 2 to Router via wired connection?
Nov 11, 2020Guru - Experienced User
I recommend syncing the RBS wirelessly first the the RBR, then after they are fully connected, connect the ethernet cable to to the RBS from the RBR.
- Pdob85018Nov 11, 2020Aspirant
Thanks again for the advice! My only remaining concern on this is that my wiring for the Router - Sat 2 backhaul is older Cat-5. I'm still thinking this will be better than wireless daisy chain backhaul, but not sure.
- FURRYe38Nov 11, 2020Guru - Experienced User
Ya, Need to upgrade to CAT6 would be best. CAT5 only supports 100Mpbs vs 1000Mpbs with CAT6.
Pdob85018 wrote:Thanks again for the advice! My only remaining concern on this is that my wiring for the Router - Sat 2 backhaul is older Cat-5. I'm still thinking this will be better than wireless daisy chain backhaul, but not sure.
- YamvmaxJan 23, 2021Aspirant
Cat5 does just fine with 1000mb. Is cat6 better? Absolutely, but its not neccesary.
