randomtask
Jul 08, 2021Tutor
Orbi RBK753S - Devices keep disconnecting and reconnecting
I recently installed the Orbi RBK753S mesh system with one wireless satellite and one backhauled satellite and while my coverage and speeds have increased over my previous setup, I keep getting notif...
randomtask
Jul 08, 2021Tutor
Thanks for the response!
I'm on v3.2.18.1_1.4.14 and including the basement it's about 2450 square feet. I have Metronet Fiber for internet using a Nokia modem (ONT 3FE56389ABBG).
I have one satellite on each floor between the basement, main floor, and second floor on alternating corners of the house so they are at least 30 feet apart. Right now 2.4GHz is set to Auto while 5GHz is set to 48. I usually do not see any neighbor's WiFi networks, though they show up every once in a while but typically one if any.
I will try your suggestions, though I'm not certain what the implications are of some of these settings... ha!
Jul 09, 2021Guru - Experienced User
Keep us posted...
