randomtask
Jul 08, 2021Tutor
Orbi RBK753S - Devices keep disconnecting and reconnecting
I recently installed the Orbi RBK753S mesh system with one wireless satellite and one backhauled satellite and while my coverage and speeds have increased over my previous setup, I keep getting notif...
randomtask
Jul 09, 2021Tutor
It would seem like this forum tries to help you post images and consequently breaks and malfunctions... so here is a link to the screenshot: https://i.imgur.com/TrQZAZA.jpg
- FURRYe38Jul 09, 2021Guru - Experienced User
Is AX mode enabled or disabled on the RBR?
What is the current CTS value setting?
What channels are you using currently?
- randomtaskJul 09, 2021Tutor
AX is enabled for both bands and I have CTS/RTS Threshold set to 2347 as previously suggested for both bands. 2.4GHz was previously set to auto and I switched it last night to 6. 5GHz is currently set to 48.
Try disabling AX on 2.4Ghz...
