randomtask
Jul 08, 2021Tutor
Orbi RBK753S - Devices keep disconnecting and reconnecting
I recently installed the Orbi RBK753S mesh system with one wireless satellite and one backhauled satellite and while my coverage and speeds have increased over my previous setup, I keep getting notif...
Jul 09, 2021Guru - Experienced User
Is AX mode enabled or disabled on the RBR?
What is the current CTS value setting?
What channels are you using currently?
randomtask
Jul 09, 2021Tutor
AX is enabled for both bands and I have CTS/RTS Threshold set to 2347 as previously suggested for both bands. 2.4GHz was previously set to auto and I switched it last night to 6. 5GHz is currently set to 48.
- FURRYe38Jul 09, 2021Guru - Experienced User
Try disabling AX on 2.4Ghz...
- randomtaskJul 09, 2021Tutor
For the sake of troubleshooting, I will give this a shot... however with AX being a main feature of this system I would hope it's not necessary to disable it in order for the system to work properly. Will follow up after some time!
Did you get access to the beta FW?
