brsboarder
Sep 11, 2020Aspirant
Orbi RBK753S and AT&T help
I have att fiber with the Arris bgw210 modem/router. I am trying to figure out how to connect the orbi properly. I still want access to the att arris wifi so that certain devices don't get connecte...
Sep 11, 2020Guru - Experienced User
You have a couple options if you want to keep the att wifi running.
1. put the orbi's IP address in the att devices dmz
2. put the orbi in access point mode. This disables its router functions and lets the att device run them. You can still use the orbi for wifi and ethernet.
- brsboarderSep 11, 2020Aspirant
Slightly confused on this step, on the att setup page, I'm assuming I go to the IP Passthrough then I have options:
Allocation Mode: Off/Default/Passthrough
Passthrough Mode:DHCPS-dynamic, DHCPS-Fixed, Manual
Passthrough Fixed MAC Address: choose from list
Thanks for all the help
