hownc
Aug 02, 2020Aspirant
Orbi RBK753s and CM1150 cannot get giga bit speed
Hi: Just upgraded from RBK50 to RBK753S. I also has CM1150 modem and Comcast giga bit connection. The speed test result is similiar as RBK50: about 600 bps. What went wrong?
Aug 03, 2020Guru - Experienced User
How are you testing? wireless? using the built in speedtest in the netgear app? If so, I wouldn't recommend it. I haven't found it max out gigabit yet.
What app are you testing with? What site are you using? many sites can't max out gigabit or if they can, sometimes need a different server picked.
I'd recommend connecting a pc directly to the cm1150v and seeing what speed you get at that point.
- howncAug 03, 2020Aspirant
I am using a laptop with WIFI 6 card and testing wirelessly. The app is Xfinity speedtest and others. They all show similiar result
Using a laptop connect directly to the output of CM1150C I got 690 - 1108 bps, most of the time 850-890 bps
