hownc
Aug 02, 2020Aspirant
Orbi RBK753s and CM1150 cannot get giga bit speed
Hi: Just upgraded from RBK50 to RBK753S. I also has CM1150 modem and Comcast giga bit connection. The speed test result is similiar as RBK50: about 600 bps. What went wrong?
hownc
Aug 03, 2020Aspirant
After I power off and connect a PC using a cable, it is showing 890+ bps.
But now when I switch back the previous setup, it is down 560 bps now. ???
Aug 04, 2020Guru - Experienced User
hownc wrote:After I power off and connect a PC using a cable, it is showing 890+ bps.
But now when I switch back the previous setup, it is down 560 bps now. ??? ----You mean where you were testing via a wireless setup? If so, thats going to have variable speeds. Between distance, obstructions, interfernce, the speed isn't going to be as stable or fast as wired.
